Fecha actual Vie Abr 04, 2025 10:24 am
Nuevo tema Este tema está cerrado, no podes editar mensajes o enviar nuevas respuestas  [ 3 mensajes ]
NotaPublicado: Sab Sep 11, 2010 10:30 am
Este es el programa en cuestión, lo necesito para un juego OSS en el que estoy colaborando desde hace tiempo:
http://dev.alientrap.org/wiki/netradiant
El tema es que al querer compilarlo, (el source lo descargué desde el GIT) me saltan estos errores:
luciano@luciano-desktop:~/netradiant$ make
checking that the build tools exist
Checking for /bin/sh (bash (or another shell))... found.
Checking for echo (coreutils)... found.
Checking for echo -n (coreutils)... found.
Checking for cat (coreutils)... found.
Checking for mkdir -p (coreutils)... found.
Checking for cp (coreutils)... found.
Checking for cp -r (coreutils)... found.
Checking for rm -f (coreutils)... found.
Checking for rm -f -r (coreutils)... found.
Checking for mv (coreutils)... found.
Checking for echo test | tee /dev/stderr (coreutils)... found.
Checking for sed (sed)... found.
Checking for find (findutils)... found.
Checking for diff (diff)... found.
Checking for cc (gcc)... found.
Checking for g++ (g++)... found.
Checking for ranlib (binutils)... found.
Checking for ar (binutils)... found.
Checking for pkg-config (pkg-config)... found.
Checking for unzip (unzip)... found.
Checking for git (git-core)... found.
Checking for svn (subversion)... found.
Checking for wget (wget)... found.
Checking for ldd  (libc6)... found.
All required tools have been found!
checking that the dependencies exist
Checking for glib/gutils.h (libglib2.0-dev)... found.
Checking for libxml/xpath.h (libxml2-dev)... found.
Checking for png.h (libpng12-dev)... found.
Checking for GL/gl.h (mesa-common-dev (or another OpenGL library))... not found, please install it or set PKG_CONFIG_PATH right!
To see the failed commands, set DEPENDENCIES_CHECK=verbose
To proceed anyway, set DEPENDENCIES_CHECK=off
Checking for gtk/gtkdialog.h (libgtk2.0-dev)... found.
Checking for gtk/gtkglwidget.h (libgtkglext1-dev)... not found, please install it or set PKG_CONFIG_PATH right!
Checking for dlfcn.h (libc6-dev)... found.
Checking for zlib.h (zlib1g-dev)... found.
make: *** [dependencies-check] Error 1
Y lo peor es que tengo ambas librerías que me pide (mesa-common-dev y libgtkglext1-dev)
¿Alguna sugerencia? :S
NotaPublicado: Lun Sep 13, 2010 6:36 pm
Solucionado: esto fue lo que hice:
1) Descargué el driver propietario de la web de NVidia, lo mandé a mi carpeta personal y le di permiso de ejecución con:
sudo chmod +x nombredriver.run
2) CTRL+ALT+F1 (o sudo /etc/init.d/gdm stop) para ir al modo sólo texto.
3) Borré todo rastro de drivers Nvidia (tengo una placa Geforce FX5500) y también borré el driver nouveau.
sudo apt-get purge remove nvidia*
sudo apt-get purge remove  xserver-xorg-video-nouveau
4) Luego, en /etc/modprobe.d/blacklist.conf, agregué esto al final del archivo:
blacklist vga16fb
blacklist nouveau
blacklist rivafb
blacklist nvidiafb
blacklist rivatv
5) Instalé el driver propietario:
sudo sh nombredriver.run
6) Configuré con nvidia-xconfig
7) Reinicié
8) Una vez en Ubuntu, ya con el driver andando, nuevamente terminal:
sudo nvidia-settings
9) Configuré pantalla y guardé.
NotaPublicado: Lun Sep 13, 2010 6:57 pm
Gracias! A alguien le va a servir alguna vez y siempre que uno soluciona algo no lo postea... ¬¬
Cierro :salud:
[ Time : 0.018s | 16 Queries | GZIP : On | Load : 0.51 ]
